Error
What exactly do you click right before you get that error message?
It seems you uninstalled the package manager before uninstalling LabVIEW (Which got installed using NIPM).
Have you tried reinstalling the package manager first?
Message 11 of 16
(1,215 Views)
Yes I think I first uninstall the pacakge manager
When I click the install button
There is pop up window where you have to answer in yes or no
Then I get that error which I sent in previous message
When I install the NI package installer there is show that error
Message 12 of 16
(1,197 Views)
HI Aniket,
@Aniket2001 wrote:
Slow means when I don't install the labview my laptop start in 30-40 sec but when I install the labview my laptop take time up to 4 -5 minutes so I think because of labview this is happened so I uninstall it
Recent Windows version support a "fast boot" option (by default), which basically only puts the computer into a sleep mode instead of really shutting down.
The LabVIEW installer switches this option OFF, now the computer really shuts down and has to really boot up when you switch it on.
Two options:
  1. Disable the option to switch off "Fast boot" when you install LabVIEW. (You will get asked in the installation process!)
  2. Turn on the "fast boot" option in the energy savings settings dialog in Windows…
Message 13 of 16
(1,191 Views)
Thank you for your support
But I installed NI LabVIEW
So now not get any error while installing the LabVIEW
Once thank you
Message 14 of 16
(1,186 Views)
Please don not constantly attach new gigantic pictures with exactly the same message. Once is enough! If you would quote the actual error message, people can later search for it and find this discussion if they have the same problem in the future!
"Cannot find NiPackageManager.exe"
This is not helpful at all unless you tell us what the question was and if you answered yes or no. Please clarify!
Message 15 of 16
(1,167 Views)
I find the some file of National Instruments in program data file
So I delete all files
After that i reinstall th ofe NI package manager and I don't get any error
And install the labview and I don't face any problem
So now there is no problem for install the lab view
Thank you for your support 🙏
Message 16 of 16
(1,163 Views)
