Estimating exponential decay time constant - taking tangent lines
How would you go about estimating a first order decay time constant? I have a system that loses heat very slowly and I wish to estimate the time constant from the first part of the data to allow for more frequent tests (I know what it will end up decaying to).
I know that I can make a good estimate based on the initial slope of the graph but I don't know how to implement this in LabVIEW. Does anyone know how I can make the VI calculate a tangent line to a graph and find where it intersects another line?
(4,645 Views)
Accepted by ipatka
How about using the
Exponential Fit VI
Owning Palette: Fitting VIs
Requires: Full Development System
Returns the exponential fit of a data set (X, Y) using the Least Square, Least Absolute Residual, or Bisquare method.
This VI uses the iterative general Least Square method and the Levenberg-Marquardt method to fit data to an exponential curve of the general form described by the following equation:
f = aebx + c
where x is the input sequence X, a is amplitude, b is damping, and c is offset. This VI finds the values of a, b, and c that best fit the observations (X, Y).
Greetings from Germany
Henrik
LV since v3.1
(4,620 Views)
Thank you! I had tried this before but I had an exponential decay that didn't die out to zero. This was causing weird results with the damping indicator. I solved it by subtracting the vertical offset from all of my values so it died out to zero and now it correctly gets the time constant.
(4,610 Views)
guess what the c is for 😉
Henrik
LV since v3.1
(4,593 Views)
Ah....I feel foolish
(4,586 Views)
