Ethernet/IP CIP Labview
I need to receive data from a Pyramid Solution Bridgeway(Ethernet To J1939 Gateway) in Labview.  Need to request this data using Ethernet/IP CIP using Class=4, Instance=100, & Attribute=3.
Mike
mikefarmer@enrgies.com
(6,025 Views)
is there a solution? i have the same problem. in the datasheet of my PLC are only informations about class, instance and attribute.
is there a labview example for it? is there a .dll to implement?
hope you can help me....
pierceg
(5,929 Views)
Hi PierceG,
When you saying Ethernet/IP CIP, I am assuming that you are referring to EthernetIP. LabVIEW does not have native VIs that can communicate using this protocol. You can develop a custom driver VI to get around this.
Hope this helps!
Warm regards,
Karunya R
(5,899 Views)
