Eurotherm 2704 connection via serial port with ModBus
Yes, but i cannot find the right drivers.
it is not that i want a copy paste solution but when i see how this guy it fixed, i think i can do it self in a shorter time then when i start at zero
Message 11 of 14
(1,723 Views)
Many manufacturers keep the command sets the same (within the limitations of the different instruments) for similar types of instruments or controllers. I would suggest downloading a MODBUS Eurotherm LabVIEW driver for another controller, downloading the "programming manual" or equivalent from Eurotherm and seeing how close they might be, command wise. Then you can use the parts that are the same, and modify, having seen how Eurotherm does certain things, those that aren't the same, or don't exist. This later part, of seeing how Eurotherm does things, is important. Modbus defines a communications protocol, how it is implemented varies widely from manufacturer to manfacturer.
Good Luck. Once you have a start it is probably a good idea to start a new thread mini8 specific, so that someone who might not have looked at this thread, they might not have a 2704 or interest in it but might be working with a mini8 or something equivalent, will see the new thread. Also, many people, in my experience, post and check the threads only when they have a problem, may be too wrapped up in their work after getting an answer, or pointed towards one, to look at even their own posts, so the original poster may not be back for a while, if ever.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 12 of 14
(1,708 Views)
I will maybe post my solutions over here.
i found a modbus library from NI.
and i can read and write registers, so the rest will be possible to do.
but i'm going to try it also on the way you described to find the best solution
thanks
Message 13 of 14
(1,687 Views)
remove this double post please
Message Edited by pshyto on 02-25-2010 09:24 AM
Message 14 of 14
(1,684 Views)
