Even been any non-proprietary instrument calibration vi's?
@CalLab_Mark wrote:
So you're saying this forum is only for programmers to learn from each other?  USERS don't come here looking for programs?
Yes.
If you are looking for someone to write this program for you, they'd most certainly want to be PAID for it.
I would.
You can post your project at http://forums.ni.com/t5/LabVIEW-Job-Openings/bd-p/JobPost
You may get plenty of people from overseas willing to do the job for cheap.
Message 11 of 16
(1,556 Views)
I'm confused by your statement that your company has a huge investment in LabVIEW. How can that be with no one having any ability to program in it?
Message 12 of 16
(1,541 Views)
It is what it is.  We have about 40 Labview stations and most of them move around as needed and run workhorse programs as well as custom.  Only one guy does the programming as a sideline to his main gig.  I just keep track of the DAQ cards & calibrate them.
I wasn't looking to employ anyone to "re-invent the wheel"--I just wanted to know if it had already been done.
Message 13 of 16
(1,513 Views)
I don't doubt for a minute that other cal labs have developed custom programs just like this one programmer that you do have. I don't doubt that the other cal labs would treat these programs as proprietary and not open source. Such programs would give a lab a competitive advantage. That's why you haven't been able to find anything and no one here has seen anything either. Don't be offended by the suggestions to create your own programs. It's really the only practical thing you can do. Press your company to hire someone or contract it out.
Message 14 of 16
(1,506 Views)
@CalLab_Mark wrote:
[...] My company has a huge investment in Labview [...]
@CalLab_Mark wrote:
It is what it is.  We have about 40 Labview stations [...]
Your company has a huge investment in stations which were programmed in LabVIEW, not LabVIEW itself (regardless of licensing).  This is exactly the type of misunderstanding (that the tools written in LabVIEW = LabVIEW) that leads to people putting "proficient in LabVIEW" on their resume.  Smiley Mad
Grrrrr...
Jim
Message 15 of 16
(1,498 Views)
If you need to connect standards to the equipment to be calibrated, it may never be completely automatic.  That being said, the equipment may have internal calibration routines you can call programmatically that will walk you through a calibration.  It might even have an external "Electronic" calibration kit that can be controlled from the internal calibration routine to make it totally automatic (except for the connecting and disconnecting of the standard, itself).  It should be fairly trivial if you have a programmer's guide.  You probably only need to send the command to calibrate and let the internal routines prompt the user.
If you have to calibrate cables and stuff, you will have to develop your own code.  Which, while not being trivial, should be pretty straightforward, provided you know how to do it manually.
Bill
CLD
(Mid-Level minion.)
Message 16 of 16
(1,478 Views)
