Event Case
I have to report an issue about this solution the High Resolution Relative Seconds VI putted in a loop can cause an Out of memory in a short time. That was why I have always inserted it in a case struct to make it start only when needed. Is there a better why to solve it?
Best Regards,
Zuc
Message 11 of 13
(1,410 Views)
Does it have to be the High resolution ?  Try replacing Both by Tick count.
Message 12 of 13
(1,392 Views)
That really cannot happen unless you autoindex at the loop boundary and create an array of ticks, one per iteration, forever.
The high resolution relative seconds is quite lightweight and does not significantly contribute to the loop overhead. Of course it is only really necessary to do it once after the loop (using proper dataflow to enforce execution order) as shown above at the cost of slightly more diagram code.
Message 13 of 13
(1,383 Views)
