Event-Loop and parallel while-loop or better two event-loops?
Oh where is that "trip to Grandmas' post of mine?
Edit Here it is
Message 21 of 26
(1,209 Views)
I think it starts here:http://forums.ni.com/t5/LabVIEW/Interrupt-a-an-unfinished-state-in-a-QSM/m-p/2820274#M825410
FYI, it is tagged with "Grandma" so you can find it quickly next time.
Message 22 of 26
(1,204 Views)
That was tagged with Grandma about a minute ago while editing my last post hereSmiley LOL
Message 23 of 26
(1,200 Views)
Regardless, it is one of the best analogies I have ever seen for a state machine gone mad.  I'll definately be using it whenever I get my user group going.
Message 24 of 26
(1,195 Views)
Does error handling trap the error that occurs if grandma gets run over by a reindeer?
Bill
CLD
(Mid-Level minion.)
Message 25 of 26
(1,181 Views)
@OnlyOne wrote:
I really would use a queue but the problem is that i then cannot stop the running vi.
1. I press "Start" in the event -> queue is starting my Measurement-vi which is running for some minutes
2. I press "Stop" in the event -> queue is queuing this command and waiting for start is finished before processing stop.
So with queue i cannot stop the vi, thats why i use globals.
1. Press Start will queue start which will setup measurement and queue Measure.
2. Measure measures (e.g. 0.1s worth of data) and queues measure until done.
3. Press stop will queue stop which'll stop the program after the next measure
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 26 of 26
(1,162 Views)
