Event Structure Components in Eval Version?
Does the Labview Eval Version include the Event Structure Components? If so, where are they located? If not, that is very lame. It is very difficult the experiment with functionality without them.
(3,289 Views)
Hi dbaechtel,
AFAIK you could access all features in the evaluation time. You should find the event structure in the Programming->Structures palette...
(3,281 Views)
The evaluation version of LabVIEW is the Professional edition. It does contain the event structure.
(3,239 Views)
You get everything you possibly want with the evaluation version.  As others have said, it's basically the professional version.
In addition, you can evaluate any toolkits and modules. (not sure if there are minor exceptions?)
Once you purchase a license, they license determines what you are allowed to use. The DVD is the same for all versions.
AFAIK, you can evaluate almost anything without jumping through any hoops. Even if you have an existing activated LabVIEW installation, you can later evaluate a toolkit or module with it.
(3,235 Views)
