enumeration conflict
I am getting an enumeration conflict with the averaging type input of the fractional octave analysis VI.
"You have two or more enumeration data types wired together, but the enumerations are different. The list of items in the enumerations must be exactly the same."
The problem is that I only want to give the user 2 options - exp or linear, I don't want option 2 or 3, just 0 or 1. Howe can I force this VI to accept my input?
(9,995 Views)
Hi
It's not the right way to force the vi to accept your enumeration type. I'd suggest you creating a case structure and wire you enum to it. Inside the case structure you can place the enumeration of the vi.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(9,985 Views)
There is an option of programmatically disable items on front panel control (attached)
Sergey
(9,977 Views)
Enumerations are for the programmer, not the user.  It is best to decouple the enumeration type from the user interface, and then typecast back to an enumeration to run the function.  This decoupling will allow for a more manageable code.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(9,974 Views)
In my vi it shown that You have two or more enumeration data types wired together, but the enumerations are different. The list of items in the enumerations must be exactly the same. But  I don't know what should I do. How can I disable or change this error. I'm a new user.
(9,197 Views)
duplicate post
required information is in the other thread.
(9,172 Views)
