Event Structure
@stevem181 test1vimod.vi is perfect for my application. Thanks you. I would like to make one more modification to the code. I would like to have a button in the front panel. I want the indicator to light up (or the event to occur) only once after the button has been pressed. ie Everytime I press the button, the first time the condition (comparison) is satisfied I want the event to occur (indicator to light up) Can this modification be made without changing the structure of the program . Thanks again for your help.
Message 11 of 15
(1,351 Views)
There are many ways this could be done. Here is one way.
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 12 of 15
(1,346 Views)
Perfect! Thank you!
Message 13 of 15
(1,329 Views)
Hi , I am trying to integrate the new piece of code in the main program. The main program is 'TMS Trigger and Save_modified.vi' In this progam, currently, the trigger is being sent when We press 'F8' or the 'Trigger button'. I would like to replace this trigger with the output of the indicator 'Limit?'. I tried doing this but ended up with an error message. I think this was mainly due to the fact that I'm trying to replace one type of input with another. -Priya
Message 14 of 15
(1,283 Views)
How do we take a variable outside the while loop. The indicator Limit? lights up, but Limit?2 does not.
-P
Message 15 of 15
(1,269 Views)
