Showing results forΒ
Search instead forΒ
Did you mean:Β
Event based structure
Greetings,
I have created a vi that requires user interaction and button presses for a lengthy chain of tests. I used an event based structure (that has around 30 states).
I was wondering if there was a way to automatically transition from one event to the next, rather than requiring the button pushes.
I'm not looking for efficiency and I understand that it is not the best approach, however I would like to be able to quickly transition to autonomy rather than redeveloping the vi using a state machine or other.
Can I transition from 1 event based state by changing a value or mimicking a button press at the end of one state?
Or is there a easy (low time consuming) way to transition from an event based structure to another structure that will do what I need?
(1,860 Views)
Hi Rentschler,
Yes.
Use a "Value (signalling)" property node…
(1,857 Views)
@GerdW wrote:
Hi Rentschler,
Yes.
Sometimes we don't have the luxury of doing it the "right" way.  Real life sucks, sometimes.  πŸ˜‰
Anyway, to add a bit to @GerdW's post, Value (Signaling) won't work if your buttons are all "Latch When Released", which is the default mechanical action for a button.  You will have to change each of them to "Switch When Released" and set the value back to FALSE in the event case that contains it.
Bill
CLD
(Mid-Level minion.)
(1,836 Views)
