Event issue: update graph while parameter change
Here is setup, I'm trying to realize (please, see the scrrenshots below):
  • quadratic equations with 3 parameters a, x0 and l
  • a and x0 are controlled by sliders whreas l is controlled by button, that generates random value
  • when some of these 3 parameters changes, graph must be updated
I realize this VI using event structure, which has 3 event cases:
  • timeout
  • either a, x0 or l changes
  • button updates l
When a or x0 change, the concept works perfectly, whereas new l value only change indicator, but graph isn't updated.
Where I've been mistaken.
Pavel
(4,674 Views)
Your "problem" is that writing a value to l does not fire a value change event. Therefore, your l value changed event will never execute when you press "Generate l".
One option is to write the random l value to l by using a value signaling property node.
Another option is to combine Generate l in l value changed event. That requires some overhead in checking if Generate l was creating that event and then compute a new l (case structure!).
Anyways, please add a stop button and code which stops the loop!!!!!!!!
Norbert
Norbert
Expert: Geometry
(4,667 Views)
Accepted by Pavel_47
When you programmatically change a Front Panel Control or Indicator, this does not generate a Value Changed Event.  To get a Value Changed Event for I, you need to use the Value (signalling) Property for I in your Generate I Value Change case.  Right-click the I indicator, choose Create Property Node, choose the Value (signalling) property, set it to Write, and wire the new value of I into it.  Note that you do not need to wire into I, itself.
(4,658 Views)
Ok, it works.
Thanks a lot.
(4,641 Views)
