Event structure problem...
Then wrap all of your code in that event case in another case structure where True means active and has all the code and and False means inactive and has nothing.
Message 31 of 36
(1,440 Views)
I was thinking about this too, but I think this is a brutal solution. Nonetheless, it might happen I will have to use this solution unless I find a way to deal with this using the Event structure.
Message 32 of 36
(1,438 Views)
If static events could be deleted… it is equivalent to modify/erase code during run-time. I wonder if that feature was enabled, whether we will see LabVIEW virus.
Maybe Microsoft/Agilent are working on those. Smiley Happy
Message 33 of 36
(1,420 Views)
I think he was referring to ignoring the event.  Not to deleting code..  😉
Since the code has to be compiled before execution, I doubt you'd be able to use that approach to modify code that is running.
Message Edited by JoeLabView on 06-15-2008 09:53 AM
Message 34 of 36
(1,398 Views)
So Joe is there a civilized way to ignore an event?
Message 35 of 36
(1,376 Views)
You should have some code inside the event case to decise if you want to run some code.
If you have a 'lock FP during event' event and the event is in a false statement and can't be executed you will lock your user interface.
Ton
My LabVIEW Ideas
Message 36 of 36
(1,351 Views)
