‎08-07-2014 08:55 AM
What happens in my code if I deleted Time out case in the event structure and run the code .
Solved! Go to Solution.
‎08-07-2014 08:58 AM
Easy to test...
The event structure will wait until one of the events that you defined occurs.
Regards, Jens
‎08-07-2014 09:01 AM
It will behave similarly to wiring a -1 to the Timeout... aka... it will not time out (it will wait until an event occurs).
If you haven't connected anything to the blue "Event Timeout" connector in the top left of the structure, the default value of it is '-1'. That means that the timeout event is never executed.
In this case, you can savely delete that case.
Norbert
