Event structure with out time out
What happens in my code if I deleted Time out case in the event structure and run the code .
(2,922 Views)
Easy to test...
The event structure will wait until one of the events that you defined occurs.
Regards, Jens
Kudos are welcome...
(2,919 Views)
It will behave similarly to wiring a -1 to the Timeout... aka... it will not time out (it will wait until an event occurs).
If someone helped you out, please select their post as the solution and/or give them Kudos!
(2,914 Views)
Accepted by topic author prajwal.prithviraj
If you haven't connected anything to the blue "Event Timeout" connector in the top left of the structure, the default value of it is '-1'. That means that the timeout event is never executed.
In this case, you can savely delete that case.
Norbert
Norbert
Expert: Geometry
(2,913 Views)
