Event structures in multiple simultaneous programs.
Main.vi with a sub popup.vi called via vi server.  Popup.vi is built into a .llb file to be called from main
and is also built into an .exe to be used as a stand-alone application.
If I use an event structure in main.vi and a different event structure within popup.vi will the two coexist
peacefully when popup.vi is called from within main?  It feels like they should be ok.  Thanks for any input.
Matt
(2,806 Views)
Yes, that should work.
(2,802 Views)
Thanks for the quick reply.  If it doesn't work I'll continue the thread 😉
Matt
(2,792 Views)
