Exacting data from variant
What I get as an output is
The issue is that I would like simply the text in quotations. Most ways I've attempted to do this (flatten to string) or grab from properity nodes isn't working.
Any suggestions?
(The goal is to automatically load/unload clusters without carring about what they store internally).
(3,891 Views)
Are you trying to simply get the name of all controls in a particular cluster?  If so, I would suggest using property nodes as shown below.
If this is not what you are trying to do please explain what you are trying to do.
(3,875 Views)
The issue is that a clusters connecting to a subVI check that
Cluster wired and cluster input have the same data model (or something similiar to this), I cannot make this garentee. Otherwise your system would work.
My input is a variant, not a cluster. (Well it is a cluster, that has been flattened to a variant, because my goal is to not force 1 type of cluster will always be used).
(3,865 Views)
Accepted by Valarauca
What you need is the datatype of the control, not its label. This vi is probably what you need: GetTypeInfo.vi from the vi.lib -> utility -> VariantDataType folder.
ben64
(3,848 Views)
Using the VIs from the same library you can validate the cluster elements datatypes by doing something like this:
Ben64
(3,836 Views)
