Example VI for a Vektrex current pulse generator
Would anybody happen to have an example VI for a Vektrex current pulse generator,
using visa commands, and an ethernet interface.
The company Vektrex does not offer a LabVIEW driver for this or any instrument.
The problem is I can communicate with the instrument correctly, however repeated operations I'm running into a
communication disconnect problem.
I'm fairly new to LabVIEW ethernet interface communication,
So I thought perhaps somebody else has produced a Vektrex current pulse generator VI and this may show what I need to add in order to get reliable operation.
I know this is kind of an overall general request but if somebody also had any instrumentation VI that uses an ethernet interface that may be helpful.
I'm using LabVIEW 2015
Thank you
(1,642 Views)
If it uses the same SCPI over ethernet, nothing special is required, you can use VISA APIs as you would do with GPIB/USB/RS232 protocols.
Santhosh
Soliton Technologies
(1,606 Views)
Based on my uses of other ethernet interface based instruments that's kinda what I thought.
However.. Nice to hear the reassurance ..
Thank you
(1,593 Views)
I don't know the model you've but based on this document, it is just SCPI over ethernet
https://www.vektrex.com/downloads/SS200HC.pdf
Probably you are good with VISA APIs or as the company 'claims' try getting the LabVIEW APIs
Santhosh
(1,587 Views)
