Example using un/bundle in a book
I was reading a book about labview and i wanted to try an example there.
What is the best way to solve this error?
(3,190 Views)
Accepted by A.A.A.
You seem to be wanting to operate on an Array of Employee Records.
On the Front Panel, create an array control and put your Employee record inside.
Instead of using a local variable, create a new indicator for your new array with the inserted record.
(3,187 Views)
For some reason LabVIEW keeps crashing when I try you suggestion.
(3,185 Views)
Thank you for the suggestion 🙂
Personal Note: Turns out undoing the array of clusters crashes labVIEW.
(3,180 Views)
