Exaprom iTextSharp footer problem
I'm using Exaprom pdf but I have a case I just can't get to work. I am generating many test files with different formats. I then compile them into a single file where each file becomes a chapter. To make the page numbers make sense I use a numbering format of "Page x - y" where x is the chapter number and y is the page number in that chapter. In the files that just imbed labview control images it works just fine. The page number work. But when I just use text from a file it fails. I have included a vi that shows this failure. If you run it with page numbering turned off it runs. Turn numbering on an the pdf fails to close.
I am using LV11 and Exaprom 1.0.
Norm
(5,451 Views)
Could you save in LV2009?
(5,438 Views)
(5,402 Views)
Unfortunately, this is LV2011.
(5,390 Views)
(5,370 Views)
Accepted by Viper
For a reason unknown from me, you have to specify a font in the page number.
Normaly, if you leave the font name empty, then it is suppose to be the default font.  If you don't specified a default font, then it is suppose to be helvetica.  I don't know why it is not working...
(5,363 Views)
