Exaprom iTextSharp footer problem
I'm using Exaprom pdf but I have a case I just can't get to work. I am generating many test files with different formats. I then compile them into a single file where each file becomes a chapter. To make the page numbers make sense I use a numbering format of "Page x - y" where x is the chapter number and y is the page number in that chapter. In the files that just imbed labview control images it works just fine. The page number work. But when I just use text from a file it fails. I have included a vi that shows this failure. If you run it with page numbering turned off it runs. Turn numbering on an the pdf fails to close.
I am using LV11 and Exaprom 1.0.
Norm
(5,350 Views)
Could you save in LV2009?
(5,337 Views)
(5,301 Views)
Unfortunately, this is LV2011.
(5,289 Views)
(5,269 Views)
Accepted by topic author Viper
For a reason unknown from me, you have to specify a font in the page number.
Normaly, if you leave the font name empty, then it is suppose to be the default font.  If you don't specified a default font, then it is suppose to be helvetica.  I don't know why it is not working...
(5,262 Views)
