Excel Active X properties and methods issue.
Hello all,
I have a project that creates an excel workbook, writes data to it, then creates charts from this data. The charts have custom textboxes that I add using properties and methods (Attached below). I am running into an issue where not all of the textboxes have been appearing (examples also attached). I just recently replaced the computer at my test station with a windows 10 machine. All excel settings are the same. Am wondering if anyone has run into this before or have any indications as to the issue. I have had trouble finding resources to the specificity of the issue. Thank you!
Message 1 of 10
(4,683 Views)
Anytime you have a piece of code that is reused multiple times, put it in a VI (this is similar to a function in C) and pass in the values that change (i.e. the textbox location and the text value/font size). This will simplify your code greatly and code changes will be much easier.
Now for your question, I'll answer it with another question.  Are the textboxes in the workbook, only hidden behind the graph?  You may need to specify a z-order value for the text box.
aputman
Message 2 of 10
(4,676 Views)
I agree with aputman, probably a z-order issue. You can use the ZOrder method of the Shape object to move it to the front.
Ben64
Message 3 of 10
(4,644 Views)
Thank you guys! I will try it and let you know if it did the trick!
Message 4 of 10
(4,577 Views)
So i added the ZOrder method for the textboxes i create an select 'msoBringToFront' but still doesn't seem to make the missing text boxes visible. I tried playing around and moving the "visible" textboxes to the back and the method didnt affect those either. Any thoughts? Attached is the updated VI.
Message 5 of 10
(4,565 Views)
Try reading the shape visible property value just to make sure it is set to true. It is probably set to true as expected but it worth checking it.
Ben64
Message 6 of 10
(4,554 Views)
Ben64,
I apologize for my lack of response, was on vacation. As for your suggestion, i set the visble property to 'true' and again the same result.
Message 7 of 10
(4,518 Views)
Since you changed the OS it is probable that the parallel operations timing is different. The suggestion I would make is to avoid creating text boxes in parallel as in the attached picture. I would also recommend you explicitly close the references when no longer required (I partly did it in the picture).
Ben64
Message 8 of 10
(4,502 Views)
Ben64,
After the Thanksgiving break I gave your last suggestion a try. I changed the VI to create the text boxes sequential instead of in parallel as well as closing the references. Though my code looks much better and seems to be more efficient, the same issue with the text box display occurs. I just don't understand how it manages to add a handful of text boxes midway through and 'miss' the others. I appreciate your help greatly!
Message 9 of 10
(4,479 Views)
Accepted by topic author DP_210435
I just wanted to follow up and say that IT never installed the service packs for Microsoft...issue is now resolved. Thank you all for your help!
Message 10 of 10
(4,436 Views)
