Number of generated Samples in a finite analog output
Hi everyone,
I want to monitor (and later use) current number of generated samples in finite analog output. I have put the node property in a while loop but it doesnt show the currect numbers. can you help me with this. Attached is the trial Vi.
(2,939 Views)
Accepted by topic author johnylowen2004
Change the monitoring part for something like this:
I would suggest you follow the free tutorial.
Ben64
(2,895 Views)
