Timeout attribute for resource versus timeout param for WaitOnEvent
Couldn't find a direct answer in the documentation for this question, so maybe someone can shed a little light. Does the timeout attribute for a resource override the timeout parameter set for WaitOnEvent ?
For example, I set the VI_ATTR_TMO_VALUE to 4,294,967,294 but set the timeout on WaitOnEvent to 5000, when does the WaitOnEvent actually return ? If I could test this myself I would, but currently I can't Smiley Frustrated
(3,610 Views)
Hi jcobb003,
What software version are you using?
Mitchell Faltin
www.ni.com/support
(3,556 Views)
I'm using the vesion of the API that came with NI-VISA 16.0. The header file says VISA library 5.7.
Note that I'm not actually using LabVIEW, I just didn't know what other board to put this. The actual implementation is being done in Ada (interfacing to C of course). Smiley Happy
(3,551 Views)
You mentioned in the original post that you are unable to test this. Why is that?
My recomendation would be to set up a test case and record results. Once we have that, we can begin to troubleshoot any issues that we run into
Best Regards,
Mitchell Faltin
www.ni.com/support
(3,533 Views)
