Excel ActiveX
I'm using vi's that I had on an old PC but they don't work because I don't have the Microsoft Excel ActiveX class on my current PC.
Do you know, please, how to install this class? Where can I find it?
Thank you in advance for your help.
Best regards
(5,376 Views)
You don't need to install anything else if you have MS Excel Installed in your new PC.
Once you have MS Excel Installed on your machine (PC) you can map the Excel.Application to ActiveX Class.
(5,329 Views)
thank you for your reply.
I have MS Excel installed on my PC but I cannot find the Excel type library (see attached image).
(5,326 Views)
Accepted by ZaADCA
probably the wrong bitness of your Excel/Office installation in comparison to your LabVIEW version. They have to match.
Regards, Jens
Kudos are welcome...
(5,324 Views)
Yes indeed you are right.
Thanks for your help
(5,321 Views)
Accepted by ZaADCA
You should get something like this, if Microsoft Excel is properly installed.
Also check in Registry Editor if its properly installed.
(5,319 Views)
Yes I have that on Labview 64bits.
Thank you
(5,315 Views)
