Excel Colour properties modified via LabVIEW
smercurio,
Thanks for the code. Unfortunately my problem persists. I've attached a screen shot of the VI you sent me as I've opened it, untouched and broken! There must be a setting or a library in LabVIEW that I don't have. Not sure where to look next. 😞
Andrew
Message 11 of 18
(3,387 Views)
What version of Excel are you running? What you would see would be dictated by that, and nothing to do with LabVIEW.
What happens if you click on the "Item" element? You should get a popup list of methods that can be selected. What happens when you re-select "Item"?
Message 12 of 18
(3,382 Views)
I'm running Excel 2007. Yes, the menu comes up when I click "item", but no change when I reselect it.
Message 13 of 18
(3,377 Views)
I figured you were probably running 2007. Microsoft often changes the datatypes on their ActiveX classes just because they like to screw around with people's code. What you will need to do is to use the Variant To Data function to convert the variant to the appropriate ActiveX class. In this case it would be the Excel.FormatCondition. You should then be able to connect the output of the Variant To Data to the property node. See attached.
Message 14 of 18
(3,356 Views)
The appropriate ActiveX class. That's the trick! Thank you for your efforts
Andrew
Message 15 of 18
(3,338 Views)
I just posted a related question in a new thread.
Andrew
Message 16 of 18
(3,286 Views)
hello at all,
someone can convert the example attached on top in 8.5 LV relase ?
 tnks
Message 17 of 18
(2,895 Views)
Message 18 of 18
(2,889 Views)
