Excel Easy Table VI append Double values
Hi, trying to apend data into tables and everything works fine except that: Indifferent of if i feed the data as double or string and they p to the connection seem right, in Excel data < 1 are saved and inserted as Nonnumbers but correct e.g. 0,768, numbers > 1 are saved as numbers but wrong e.g. 1.066,0000 instead of 1,066. What can I do about that?
(2,790 Views)
I played around a bit and got it working but only with a small trick that is dividing my original number by 1E6 to have the correct values in Excel...
Maybe someone knows a better way?
(2,777 Views)
