Excel Easy table.vi returns wrong number format and rounds off.
I changed the VI to the one I'm actually using.
I think the subject line says it all. Here's my data collected from a test instrument.
Capture.PNGHere's what I get in Excel.
Message 1 of 12
(5,038 Views)
It is just the way it is displayed in Excel, if you click on a cell and look in the formula bar you will see the real value. You can change the way Excel displays the data using the Excel Set Cell Format.vi.
Ben64
Message 2 of 12
(4,994 Views)
Accepted by topic author RHutchings
Unfortunately, at least in LabVIEW 2016, this isn't correct.  LabVIEW takes a perfectly good polymorphic function (Excel Easy Table), accepts the Dbl format, but then internally hands it to a function called "Append Numeric Table to Report (wrap)" that includes an (unwired) Format String, %.3f, that limits you to three decimal places.  You really do lose the precision [I just "did the experiment" to prove it to myself, but will leave as an "Exercise for the Reader" if changing the Cell format changes this behavior].
Bob Schor
Aha!  Solved it.  Don't use "Excel Easy Table", but instead use "Append Table to Report", which (as it turns out) is the function that Easy Table calls, but now you can specify %6.3f as the Format you want and get the Excel appearance you desire.  It still isn't saving Dbls (why not?), but you can at least control the Precision.
BS
Message 3 of 12
(4,980 Views)
Bob Schor
That's terrible!!! I don't have the time to try but I wonder if saving the data as a string table and then changing the cell format in Excel would be possible.
Ben64
Message 4 of 12
(4,977 Views)
Ben,
     I was editing my reply as you were responding to it.  It's partly solvable, but still a kludge.
Bob Schor
Message 5 of 12
(4,975 Views)
I want to try the Append Table to Report but I don't know how to build MS Office parameters. Help!
Message 6 of 12
(4,949 Views)
It is not clear (to me) why you need to worry about the MS Office Parameters.  Why don't you put together a small VI that shows what you are trying to do (and if you are unsure how to do something, put a Text Label in there that says what you want to do).  Seeing actual code, with inputs, outputs, etc., makes it much easier for "non-mind-readers" such as myself to better understand what you want to do and where you might be going astray.  I can pretty much guarantee one of us will respond within a few hours.
Bob Schor
Message 7 of 12
(4,938 Views)
Capture2.PNGOK so I got something for that but I'm getting this error when I run it. I'm including a piece of the VI. In the end, I need to collect data from an instrument, insert it into a spreadsheet, take another set of dat and insert into the same Excel sheet at the new location next to the previous data. I had everything work except the data being rounded.Capture.PNGHere's
Message 8 of 12
(4,937 Views)
Since you provide row and column position connect empty string constants to the name and bookmark inputs.
Ben64
Message 9 of 12
(4,925 Views)
Message 10 of 12
(4,921 Views)
