Excel Formatting
I am trying to change the text style in Excel using ActiveX.  I've been able to do things like set the horizontal and vertical alignment and set the row height and column width.  Right clicking on the property node and selecting Help For Style has not been very helpful. (Neither has the other Help For ... with Excel ActiveX property nodes.  I found the others on this message board.)
I would like to see some documentation on these properties and what type of data they expect.  I've even been to the excel board on breakpoint and it has alot of useful information but not what I'm looking for.  If anyone can help, I would greatly appreciate it.
Ron Deavers, CLD
(5,062 Views)
I am assuming you've installed the Visual Basic Help for Excel, otherwise the right-clicking won't display the help for that particular property/method. Other than that, the definitve help is on MSDN.
Usually the best way to figure out what you need to do is to record a macro in Excel doing what you want to do. Then, switch to the VBA editor and you can see the exact commands.
(5,055 Views)
Accepted by programmindragon
For example, if I start the macro recorder and click on a cell and select "Format -> Cells..." and set it up for Bold, 8 pt, the VBA code looks like this:
     With Selection.Font
        .Name = "Arial"
        .FontStyle = "Bold"
        .Size = 8
        .Strikethrough = False
        .Superscript = False
        .Subscript = False
        .OutlineFont = False
        .Shadow = False
        .Underline = xlUnderlineStyleNone
        .ColorIndex = xlAutomatic
    End With
This can be written in LabVIEW this way:
Message Edited by smercurio_fc on 09-05-2008 12:13 PM
(5,051 Views)
Now that is cool.  -SS
(5,044 Views)
Thank you very much.  I was trying to use the Style property of the Range property node to do my text formatting.  I appreciate your help.
Ron Deavers, CLD
(5,003 Views)
You can do it either way. I just happened to use the "Format -> Cells" just for example. Note that in the LabVIEW code you don't actually have to set a value for every property like it's done in the VBA code. You can just set the properties you need to set. In my example I really only needed to set the size and the bold attribute. The rest were shown for information.
(4,985 Views)
