Excel Get last Column
Hello,i can find the Function"Excel Get last Row" which can be used to get the Rows of a 2D Array. My question is how should i get the columns of a 2D Array, Because I can't find Function"Excel Get last Column". Please help me,Thank you very much.
Message 1 of 10
(12,822 Views)
get the entire 2d array seperate that into two 1d array and rotate that two 1d arrays and get the first element so that u can get the last element of original 2d array...
Message 2 of 10
(12,814 Views)
Use Array Functions.Use SIZE of 2D Array and it will give you the Last Column Index
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 3 of 10
(12,808 Views)
try this
Message 4 of 10
(12,801 Views)
I don't see there is a VI available for getting the last column but certainly you can read the 2d data and index the last column.
Message 5 of 10
(12,788 Views)
Accepted by topic author shawn1
You can easily create your own Excel Get Last Column.vi by modifying the Excel Get Last Row.vi code.
Ben64
Message 6 of 10
(12,767 Views)
Kudos to Ben and to NI, who provided Excel Get Last Row in an "unlocked" form to allow Ben (and anyone else sufficiently adventurous) to create the "missing" Excel Get Last Column.  Maybe NI will include this little gem in a future release of the Report Generation Toolkit.
Bob Schor
Message 7 of 10
(12,753 Views)
Thank you ,but my input parameters is "EXCEL INSTANCE",So your way may not works. but Anyway,Thanks
Message 8 of 10
(12,714 Views)
Hi Ben, Can you give me Excel Get Last Column.vi (Labview2013)?? I can't open this vi(Labview2015). Thank you
Message 9 of 10
(12,708 Views)
get last column vi in labview 13 version...
There are  two ways to tell somebody thanks: Kudos and Marked Solutions
Message 10 of 10
(12,704 Views)
