validating a XML using XSD 1.1 schema
i am using LV13, and have a XML file which i want to validate on load using the XSD1.1 schema.
The Labview inbuilt parse (Load XML File.VI) works fine and validate my xml against XSD1.0 schema specifications.
Is there a way in which i can configure the XML parser in LV , so that is validates XML as per the 1.1 schema specification.
Thanks for your help in advance.
(5,281 Views)
It looks like if you dig into the Load XML File.VI, you eventaully reach a locked subVI that you cannot open any further.  That VI looks like the one that is doing the parsing.  Since the XSD1.0 and XSD1.1 sound like they are pretty different, I think your next best hope is to look for an existing library or you can write the parsing from scratch
(5,216 Views)
Yeah, i did the same, after digging the SUBVI are locked.
Also, after a more research i found that validating an XML with 1.1 schema may not be possible because LV uses Xerces2.7 as a native parser. Basically that parser is present behind that locked VI. Additionally, Xerces 2.7 is unstable for XSD1.1 schema specification, that is what I read on developer forum.
The only shot which I have is to create a dll and bring it inside LV environment. The latest Xerces 3.19( written in C++) has the capability to validate against XSD 1.1 and is a stable version.
(5,213 Views)
You can use MSXML  by Invoking the Methods of Microsoft XML
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(5,198 Views)
