Excel Set Color and Border VI: no fill?
If i use Excel Set Color and Border VI to modify the format of a cell, i will get white as my default color for my cell.  However, I am looking for no fill.  I don't want any color, since the color will hide the gird line.  What do I get the no fill option for cell color in LabVIEW?
Kudos and Accepted as Solution are welcome!
(5,004 Views)
Connecting transparent color to "background color" input doesn't help?
(4,999 Views)
 No, if I use transparent, black would show up.
(4,996 Views)
Accepted by jyang72211
I got it.  I just need to change the function by adding the pattern property and set it to -4142, which is no fill.
(4,993 Views)
I have to say I was waiting for this question (I have tried it and observed the same thing). The only solution I see is to use a combination of the RGT vis and ActiveX.
Ben64
note, I have connected Cell1 and Cell2 of the _Worksheet Range method but it is probably sufficient to connect only Cell1 here.
edit: Good, your solution seems a lot more simple!
(4,991 Views)
Sorry to revive a slightly old thread.
I was also having the same problem, wanting to set the cell background to No Color, and I also came across the proposed solution of using the value -4142 to achieve this.  However, it doesn't seem to work for me!
Can I just confirm the version of Excel that you use please (I'm stuck with 2002 SP3), and also check that all you are doing is wiring a signed integer to the background color input of the Excel Set Cell Color And Border.vi?
Many thanks,
Andy
(4,877 Views)
