Excel Sheet Generation Error
Dear All,
i'm trying to generate Excel Seet report using "Report Generation Toolkit" but ihave some problems.
the i'm using is attached also the erro, So please can i have help with it?
Best Regards,
(3,109 Views)
Hi , the path in the first vi is meant for template . Its not the destination path . That might be the reson for the error.
(3,093 Views)
I agree with Frabto.
Moreover, the path you are using has to be provided when saving the report (i.e. when using "Save Report to File.vi"), not when creating the report.
Marco
(3,089 Views)
Are you trying to overwrite with older one?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,060 Views)
