Excel Toolkit (GOOP)
I'm trying to use the Excel Toolkit (GOOP). I am using LabVIEW 7.1 and I was wondering where should I place the helpfiles so that they work properly?  Can you help me?
(3,544 Views)
I'm assuming that you are talking about the "toolkit" linked here [link removed; driver no longer available]. If so, it was actually developed by a 3rd party, Philips Research, so it is not supported by National Instruments. There is some contact information for the author at the bottom of the readme file included with the package, so I would recommend trying your question there. I've posted it below for your convenience:
Philips Research COS/TMA
email: martin.vernhout@philips.com
Kind Regards,
E. Sulzer
(3,515 Views)
hello
does this toolkit work with Labview 8.0?
thanks
(3,410 Views)
As I said before, any questions about the toolkit should be directed to the 3rd party creator. However, if this toolkit is just composed of basic VIs, then it should be forward-compatable with future versions of LabVIEW just like any other VI.
Kind Regards,
Message Edited by AESulzer on 04-12-2006 11:39 AM
E. Sulzer
(3,390 Views)
