Excel graph smoothing
MAH2681,
I can't get back to 7.0 but I have attached a png.  Hope this helps.
-cb
Message 11 of 14
(1,453 Views)
Thanks 10Degree, that is good enough.  I just wanted to take a look at the code to see if it might be useful since I am doing some research at the moment.
Thanks again!
Using Labview 7.0 and 2010 SP1 with Windows XP and 7.
Message 12 of 14
(1,437 Views)
I'm feeding an array of doubles in this and getting a -20049 (x values must be distinct) error out of the compute spline vi. Help please! -Zac
Message 13 of 14
(1,393 Views)
Check your array data.  As the error suggests, you can't have repeating x-values in your x-axis array.
Message 14 of 14
(1,374 Views)
