Excel is not writable in Runtime
I am using LabView 2022 Community Edition. The VI is reading values and writing it to an EXEL-File using the NI_report.lvclass:Create Report.vi. In the development enviroment it is working fine.
When i build an EXE-file it is still working fine on the development computer.
When i copy the 3 files to another computer I get the error 7: LabView attempted to locate the Class at this path: ...Application.exe/1abvi3w/vi.lib/Utility/NIReport.llb/Excel/NI_Excel.lvclass. This occures after selecting the path to store my data.
I remember, that in the older versions soemthing has to be included during building, but unfortunately i forgott the details. I'm only occasionally doing development with LabView.
Thank you for any help,
Bernd
(2,133 Views)
Have you installed an appropriate LabVIEW Runtime Engine on the PC where you are trying to run your Executable?  [Note that the machine where you installed Community Edition has the Runtime Engine already installed, needed to "run LabVIEW", of course].
(2,128 Views)
Accepted by Bernddoe1
It's probably this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019O6PSAU&l=en-US
___________________
Try to take over the world!
(2,081 Views)
Thank you, that is the solution.
Bernd
(2,044 Views)
