Excel like front panel
Hi ,
I am trying to put Spread sheet on the front panel on which I can put my data . The whole idea is to write the data on the front panel , for example there are five columns in my program. I want to put data in the columns but I aslo want to do my work easy as if I have to enter 100 values its really difficult to enter them one by one as all the values have a contast difference between them that is the first column is somthing like this  1456.3 , 1456.4 , 1456.5  to do somthing like this i want tohave somthing like excel or spread sheet in the front panel as it is already has all the funtions implemented. So if there is a easy example can someone tell me .
With Regards
Ali Asad
Regards
(3,021 Views)
Why not this ?
Please find the attachment
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,018 Views)
Something like this might help:
(3,002 Views)
Yes , I thought about this but as I want to have a fancy user interface, anyway I found ActiveX for Spreadsheet. They are working fine for me
Regards
Ali
Regards
(2,939 Views)
