Excel page opens when accessing from Labview
I have used the Excel Report genertor toolkit with Labview 2014 to access client files for verification after a barcode scan.
This has worked fine whilst client used Office 2003 but now with Office 2010 when the check takes place the Excel program is loaded and page appears on user screen before closing after Labview program has scanned the data.
The scan etc still works fine but it is distracting when the Excel file loads momentarily and wonder if there is a method to prevent this page appearing?
Labview Version 8.5
Labview Version 8.6
Labview Version 2014
(3,677 Views)
Accepted by jack1
If you had attached your VI, I could have checked it and verified the setting that I believe you omitted.  So you'll have to do the work yourself:
  1. Open your VI.
  2. Look at the first RGT function that you use.
  3. Right-click it, choose "Help" from the drop-down menu, and carefully read the description.  You may not want to choose the Defaults.
(3,654 Views)
Thanks Bob,
Missed that one and think I get the gist, attached segment of code with the Windows option which I guess should have be either minimised or normal? will check tomorrow if on the right track,
Thanks again,
Labview Version 8.5
Labview Version 8.6
(3,647 Views)
Accepted by jack1
Hint:  "Normal" is the default (which means it's what you get when you don't wire something else).  So if this is the "magic option", then "Normal" is wrong.
(3,643 Views)
Thanks Bob,sorted 'No Change' guess its obvious really .........
Thanks again,
Jack
Labview Version 8.5
Labview Version 8.6
(3,628 Views)
Ha!  You taught me something -- I'd never tried "no change", reasoning that if I wanted the most "minimal" (i.e. no) window, I should choose "minimized" ...
All's well that does what we want ...
(3,616 Views)
