Excell sub-vi's dont work after compiling.
I have created an application which gathers some numeric data and exports it to an Excell spreadsheet. I am using LabVIEW 7.0 with the MS Office addons. Everything worked great during development -- the spreadsheet is created, change the workbook names, insert the data, create a graph with the inserted data, and save the .xls file. The problem arrises after I compile the application. I checked the build setup and all the neccessary VI's for excell and report generation are there. When I run the .exe version of my VI, the Excell portion simply does not execute. No spreadsheet, no error, nothing at all. I have dug through the build setup looking for some setting, looked through the knowledge base, and I can't find whats wr
ong. Any help is appreciated. Thanks!
(2,704 Views)
Is the executable running on the same PC?
Wiebe.
"JonB" wrote in message
news:5065000000080000007EA70000-1042324653000@exchange.ni.com...
> through the knowledge base, and I can't find whats wrong. Any help is
(2,704 Views)
Hi Jon,
Here is another discussion for the report generation toolkit and exes. It contains also a link to the knowledge base.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,704 Views)
The linked knowledgebase solved my problem. Thank you for your prompt response.
Jon
(2,704 Views)
