 Ruwee
			Ruwee
			08-21-2012 03:32 AM
Hi All,
Exception: Access violation (0xC0000005) at EIP=0x7198AE7A
I do get this error on running the application on runtime version after 4 days and close. Attached are the screen shot and relevant reports.
With this application I am using cRio9075 with Ni9425 and NI 9476 modules.
Solved! Go to Solution.
 ramses64
			ramses64
			08-22-2012 10:08 AM
do you have LabVIEW Desktop Trace Execution Toolkit ? That could be a good idea to launch this program while yours is running to see errors, memory leaks, memory allocations... etc. For exemple, if you don't close a reference, this program will show you the problem....
I hope this will help you.
08-23-2012 03:34 AM
Will give it a go.
