Exception: Access violation (0xC0000005) at EIP=0x7198AE7A
Hi All,
I do get this error on running the application on runtime version after 4 days and close.  Attached are the screen shot and relevant reports.
With this application I am using cRio9075 with Ni9425 and NI 9476 modules.
(6,294 Views)
Accepted by topic author Ruwee
do you have LabVIEW Desktop Trace Execution Toolkit ? That could be a good idea to launch this program while yours is running to see errors, memory leaks, memory allocations... etc. For exemple, if you don't close a reference, this program will show you the problem....
I hope this will help you.
V-F
(6,263 Views)
Will give it a go.
(6,250 Views)
