Excluding the byte count from MQTT payload
Hey, i kinda new in the labview, basicly i have a program that read data from hardware using labview and sending the processed data into database with mqtt protocol. I have a problem that when i pubblish from the labview, it add another byte into the payload that likely to be the name of payload and the byte count of the payload. I'm using a basic mqtt publish from the library. is it possible to excluding that from my payload?
i attached the screenshot of the mqtt publish program, the payload structure and the published payload
(191 Views)
If you are flattening the data yourself, use Publish (Raw Payload).vi.
Alternatively, you could create your own Serializer object that flattens data to e.g. JSON.
(153 Views)
