Hello all,
I wondered yesterday while I am working with my PXI RT system.
My system having following components.
PXI RT Controller 8108
PXI Chassis 1042
LabVIEW 2009
LabVIEW RT 2009
NI MAX 4.6.2
The following observation on my system.
1. While running VIs in Host and RT system it works fine but after making a build for RT target and set as startup exe, it wont work at all. I am communicating with host and RT using shared variable libraries and it is deployed in RT target.
2. There is no any error while building an exe or after deployng RT exe and run the host exe, but neither I get any data from RT not I can control from Host.
3. As I serch for Remote device in MAX. I can identify my PXI chessis and the cards installed on it but while I am expanding the "Software" segment it doesn't show any software installed but by selecting "ADD/Remove Software" a new window popups and the list of Installed componets appears.
I don't know why its happening, Please Advise.
Awaiting a Reply.
Malhar Chaniyara
Application Engineer.
Greetings from India.
Greeting from India,
Malhar
