How to decipher a cluster
I could be going about this all wrong, but I have I have a Zoom FFT Spectrum that outputs in a cluster. Within that cluster I believe to be a graph but I can't find what thread it is on. Am I even correct by saying that there is in fact a graph in one of the  threads? I am trying to read the output but instead get nothing
Any help would be much appreciated. Thanks
Hova
(3,287 Views)
Hi hova try this... When you are making a cluster to give input to a sub VI that should exactly match with the one used in the sub VI... Don't leave any coercian dots in your BD... that will really create some problem...
Smiley Wink
(3,274 Views)
Thanks a lot but Im running version 8.2 and can not open your version. Could you send a pdf or image or something so I could view the file?
Thanks so much!
Hova
(3,235 Views)
I already saved it for version 8.5... Ok i have saved it to 8.0... try this..:..
Smiley Wink
(3,208 Views)
