Executable File Doesn't Work with Configuration File Functions (NI_LVConfig.lvlib) In Use
I have a problem when I built a program into exe file.
The source code can run fine, but after turn it into exe file, it doesn't work.
It has a main vi that call sub vi by opening the vi reference, and the sub vi has some functions from NI_LVConfig.lvlib ( Configuration file functions )
Here has two pictures of the demo program.
I searched NI_LVConfig.lvlib in forum and found some topics about this, but I still didnot work out this problem.
I believe this is a problem of vi dependence, that after built, the executable file cannot find the resource of NI_LVConfig.lvlib.
Best Regards!
Vincent
Message 1 of 11
(4,870 Views)
Can you try using application directory as shown inhttp://digital.ni.com/public.nsf/allkb/FD7DE8BC8FFC256C862565F4006BE363
Message 2 of 11
(4,862 Views)
Yeah, it also can get same result by using Current VI Path.
Vincent
Message 3 of 11
(4,858 Views)
Anyone who has some idea ?
BR
Vincent
Message 4 of 11
(4,844 Views)
Have you remembered to put your dynamically called subvi into the "always included" in the build specification? As it is called by reference it won't automatically be included.
Ian S
Applications Engineer CLA
National Instruments UK&Ireland
Message 5 of 11
(4,827 Views)
Hi, Lan,
I tried my demo project, it can work in right way.
I will try my test system.
It is interesting that the dynamic subvi can be called successfully without LVConfig.lvlib functions in use, so I didn't pay attention on included vis.
Thank you very much.Smiley Very Happy
BR
Vincent
Message 6 of 11
(4,824 Views)
Hi, Lan,
Please kindly help to look at my new problem.
After including all dynamic subvi into the project, the exe file turns to search VISA Configure Serial Port.
I tried to include this vi into project/re-direct the vi, but it helps nothing. The _visa.llb be included into project will affect exe file building due to it has some unexecutable file.
I use this vi in my init function for serial control.
Should I turn to include some other llb file or even other dll file for visa support?
Thank you very much!
Hope can get your kindly help.
BR
Vincent.
Message 7 of 11
(4,817 Views)
It may be that the VISA driver isn't included in the target machine?
You can include it in the "additional installers" page in the installer build.
Ian S
Message 8 of 11
(4,813 Views)
But this problem occurs on my own PC, I didn't run the exe application in test machine cause the exe build problem.
From my previous experience, I think VISA driver doesn't need to build into the exe file but ask user to install NI 488.2.
BR
Vincent
Message 9 of 11
(4,800 Views)
Hi, Lan
Could you kindly help to take a look at this problem?
Vincent
Message 10 of 11
(4,785 Views)
