Executable program not able to open
Hi Eli,
I am facing the same problem as that of HTC.
In my vi , i am reading the binary files which are stored on my local drive and then generating the word report from that information.
i have created an exe and put in on a stand alone machine with LV 8.5 run time engine already installed on it.
If i disable the report generation vis then the exe opens and functions properly but if i enable the report gen vis then
the exe opens and disappears from windows taskbar.
I tried with adding word dynamic VIs in source files but it didnot work out.
any help wpuld be appreciated.
Thanks.
Dev
CLD Certified Engineer
Message 11 of 11
(516 Views)
