Execute while loop with new variable
I have multiple parallel while loops running at different and ever changing rates. I communicate between loops with shared variables. I wish to execute the second loop only once the first loop has updated the shared variable witch is used by the second loop. i.e first loop runs, writes the shared variable at some point inside the loop (not at the end of the loop)  and only at this time the second loop should begin running and when finished waits for the shared variable to be updated in order to run again. Any ideas how this can be acieved? Thanks
(3,530 Views)
Accepted by lforni
Hi lforni,
You should use notifiers (or a queue) instead of SharedVariables…
(3,516 Views)
As Gerd says, Event, notifier or queue is the right tools for this.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,485 Views)
Look at this paper about producer/comsumer design patterns: https://www.ni.com/en/support/documentation/supplemental/21/producer-consumer-architecture-in-labvie...
Steve
(3,479 Views)
