Executing Commands Title
Hi everyone,
When I open a VI file, I see an additional title "Executing commands" before the title of the VI in the windows title bar. However, not all of the files show the same thing. What does it mean? How to remove this?
thx
(3,281 Views)
Accepted by AssassinShade
Hai,
If you would like to change the title bar heading got to  File>>VI Properties>>Window appearence>>
 You have something called "Window title".  When the text is changed there it reflects in the window title bar.
Hope this helps.  Revert back for any queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(3,271 Views)
Ah.. Thx a lot... I'm quite new in this labVIEW things T_T
(3,245 Views)
If that answered your question, then please mark JK1 post as solution so that others facing similar problems and looking for a solution will get benefitted. You can do it by clicking on "Options" at the top right corner of JK1 post and select "solution".
Mathan
(3,228 Views)
