Execution Speed Anomaly
LV 2013, Win 7
In revisiting some old code (2003), I was making some convenience "wrappers" and measuring execution speed, compared to the old version.
I found a weirdness that I cannot explain - I'm wondering if anybody has any further insight.
Basically, I time a VI of mine doing a certain operation at 390 nSec +/- 2.  I'm as careful as can be, I have a well-tested template for doing this.
The VI is subroutine priority, but cannot be inline, because it cannot be reentrant.  Fine.
But when I measure the "wrapper" function, it actually measures significantly LESS time!
Namely, 301 nSec +/- 2.
The wrapper is inline subroutine.
So, why does it get faster?  Is this real, or is the optimizer fooling me?
Here is the first test:
And here is the 2nd:
The wrapper code is here:
And the root code is here:
Attached is the timing template I developed and have used for 20+ years.  It's free.
Why is a wrapper function faster, or is it?
Steve Bird
Culverson.com
LinkedIn
Message 1 of 15
(5,979 Views)
For the record, the READ VALUES function does NOT benefit from the wrapper.  The time is exactly the same, which is what I would expect.
Also note that all subVI front panels were CLOSED during the test.
Steve Bird
Culverson.com
LinkedIn
Message 2 of 15
(5,977 Views)
What happens if it is NOT inlined?
Many years ago I did a very exotic application to test the speed difference using various transport media between PCs. I will spare you the log story but in the end I came up with a number that let me estimate how much time was required for each connector in a sub-VI icon connector. The more "spare" connectors the longer it took. Reduce the number of connectors, the faster it ran.
Since inlining is putting the code of the called sub-VI into the caller, the difference may be due to eliminating the overhead required to set and invoke the sub-VI.
A lot of speculating and hand waving I admit.
The DeskTop Execution Trace toolkit may give you some insight.
I f you learn the real answer, please let us know what you find.
Ben
Message 3 of 15
(5,951 Views)
You only attached the timing wrapper ("tester"), which is a bit Rube Goldberg for my taste. Can you also attach the "testee"
  • So you are using a millisecond ticker to measure nanoseconds. Why not use "high resolution relative seconds"?
  • What exactly determines the execution speed?
  • I probably would not use subroutine priority.
Is the image your subVI? I would probably use a feedback node instead of a dummy loop and shift register. Is this running on a PC or on a RT system?
Message 4 of 15
(5,938 Views)
It is not.
QUOTE: "The VI is subroutine priority, but cannot be inline, because it cannot be reentrant."
Message 5 of 15
(5,935 Views)
@altenbach wrote:
It is not.
Two lines later he wrote;
"The wrapper is inline subroutine."
Ben
Message 6 of 15
(5,932 Views)
@Ben wrote:
@altenbach
Obviously, we don't have all the facts. The wrapper has no connectors, so it cannot be used as a subVI and return data, meaning it is run as toplevel VI interactively. In that context, "inlined" has no meaning. 😄
Message 7 of 15
(5,929 Views)
Well, obviously all this lacks details. I guess the "Wrapper" is again something else. We need to see the entire code.
Message 8 of 15
(5,926 Views)
That would make it less challenging to answer.. yes.
But the images do suggest different icon connectors were used.
Edit:
And just for the record I have switched over too 100% feedback nodes instead of While loops with shift registers.
Ben
Message 9 of 15
(5,920 Views)
Interesting.  I just did a reboot / reload and constructed the test again.
If the wrapper is inlined, I get 315 nSec
If the wrapper is non-reentrant, but subroutine, I get 323 nSec
If the wrapper is non-reentrant, normal, I get 365 nSec.
And now, if I call to the root VI without a wrapper, I get 305.
That seems reasonable.
This time it's with no project loaded.
Don't know what I did, but apparently it's a chimera.
So, sorry for the noise.  We now return you to your regularly scheduled programming.
Steve Bird
Culverson.com
LinkedIn
Message 10 of 15
(5,915 Views)
