Exit a programme
Hi every one,
My question must have been asked thousand times but please can someone tell
me whether it is possible to programmatically have subroutines in LV. In
other words, something that would look like a quit button subroutine that
could be called to see whether this button was pressed so as to quit the
programme
I have a lot of step to accomplish in a flat sequence and I would like to
enable the user to quit in case he needs to do so.
Because this is always the same with LV, namely if the programme is in the
beginning of a process and the user pressed quit or stop
It's only at the end that this button will start its action and quit the
programme.
Thank you for your help
Gérard
Gérard Férini
Switzerland
http://home.tiscalinet.ch/
gferini/
remove -move to reply personally
Message 1 of 9
(4,541 Views)
Hello Gerard,
easy solution: check this button in every step of the sequence by using local variables. When using device communication I insert the stop signal into my error cluster.
You can make this "more complicated": using global variables, use a subvi for the emergency button, check the button in a subvi with the help of a reference and so on...
Message 2 of 9
(4,541 Views)
You could use the abort button in the menu bar to quit at any time without having to program anything. Of course this is not a graceful shutdown.
- tbob
Inventor of the WORM Global
Message 3 of 9
(4,541 Views)
Thanks GerdW for your reply.
Regards
gérard
Gérard Férini
Switzerland
http://home.tiscalinet.ch/gferini/Main_Photos.html
"GerdW" wrote in message
news:50650000000500000075D60100-1079395200000@exchange.ni.com...
Hello Gerard,
Message 4 of 9
(4,541 Views)
Hi Gérard,
I would suggest that you take a look at the State Machine structure (New� >> VI From Template >> Frameworks >> Design Patterns >> Standard State Machine).
This programming structure is extremely flexible and expandable. It basically performs a sequence, depending on the return values from each step. This means that you can go to a certain �shutdown� state if you receive an error, or if the customer chooses to stop, or you can simply stop the loop without a state.
Please play with the State Machine example and read the documentation on it for more info.
Have fun!
Philip C.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
Message 5 of 9
(4,541 Views)
Thank you Philip for this valuable suggestion. I've tried this to see by
myself what this "State Machine" had in mind.
Interesting but still waiting to see if it's going to be convincing?
Thanks anyway
Gérard
Gérard Férini
Switzerland
"Philip C." wrote in message
news:50650000000500000092D70100-1079395200000@exchange.ni.com...
Hi Gérard,
(New. >> VI From Template >> Frameworks >> Design Patterns >> Standard
State Machine).
n "shutdown" state if
Have fun!
Philip C.
Message 6 of 9
(4,541 Views)
Hi Gérard,
The State Machine is one of the most popular Application Design Patterns available. I would recommend you to read the online State Machine tutorial [broken link removed], for you to evaluate how useful it would be to implement it in your application.
Philip C.
Thinkbot Solutions
Message 7 of 9
(4,541 Views)
Sorry - here's the correct link.
Philip C.
Thinkbot Solutions
Message 8 of 9
(4,541 Views)
Dear Philip,
After some attempt trying to modify the State Machine examples LV Provides,
I design my own application just to have a better idea about this manner of
programming.
You are right, this is absolutely something NI should teach as the basic way
of conceiving LV applications.
Thank you for all
Gérard
EPFL
The Swiss Federal Institute of Technology
Gérard Férini
Departement ISIC-GE
1015 Lausanne
Phone +41216933126
gerard.ferini@epfl.ch
news:50650000000500000033D80100-1079395200000@exchange.ni.com...
Hi Gérard,
href="http://zone.ni.com/devzone/conceptd.nsf/webmain/C74CEC177A289DBD86256C4E00600196?opendocument"...
Philip C.
Message 9 of 9
(4,541 Views)
